Adrian Jebef
- Jun 25, 2010
- Los Angeles, CA
- adrianjebef.com
Here is how I compare the RAW images ( Red calls r3d raw, but it really isn't , but for arguments sake Ill go with that)
i shoot with the Red, process r3d in RCX to a 16 bit tiff sequence. Highest quality settings, non clipping color correction.
I then shoot same scene with Canon in CR2 raw format. Process in adobe camera raw to 16 bit tiff at best settings and no clipping in blacks or whites.
Both shoots rack focus slowly to ensure the best focus is captured somewhere in the sequence of frames. On tha canon I would shoot a dozen or so frames. The red gets more frames obviously because it's a movie camera.
I then color grade one to match the other . A curve fit match is enough to match if I'm mainly looking at detail issues. These steps are now in Fusion or nuke, high bit depth.
zoom in 800% of so and look at fine details.
For extra fun, look at the dark shadow details, brighten to see what detail there is visible in each. The red tends to lack detail or even noise at the darkest, almost black areas. The lack of noise is not consistent with the noise in brighter parts of the image.
Have you tried this ?
I plan on repeating this test when I receive my black magic 2.5 K camera. It has no compression and an actively cooled sensor. Should be revealing . I'm guessing Red will up the priority of improving demosaic in RCX , which will be welcomed by many.
I, too, have seen this in EPIC footage. It can be slight but it is there. There also seems to be so much confusion surrounding RED's R3D RAW workflow that most just assume that RAW = Perfect when, in fact, a RAW file is only as perfect as the sensor that created it (and is made even less perfect by compression and processing). As Les alludes to, the sensor technology in a Canon still camera, an Epic, and a host of other manufacturers is really not at all that different. Just because we now name our sensors doesn't automatically make them "revolutionary".
I look forward to seeing some of your test stills, Les.
