Mike McEntire
- Apr 22, 2008
- Age
- 63
- www.mackdawgproductions.com
Amazing! Would love to put one of these to use one day. Can't wait to see some footage from one!
The Epic-M is already being called out as a hoax on CML...
As SSD cards become bigger and faster, it’s conceivable that three HRDx images fit into one R3D file. If they could work out a solution in the 40’s, think of what they could do NOW! What was hard to-do; was coming up a monochromatic camera that has a good ASA/ISO, that is very sharp, and can render a good image. Just saying!
Humberto Rivera
I think the first monochrome Epic M should be named Ansel.
I used the IR Red One to shoot extensive sequences for a movie coming out next year. It's an amazing type of cinematography. A lot of the rules we tend to live by go out the window when shooting IR.
Jarred, do you have any plans, as of right now, to convert one of these monochrome cameras to IR and rent it out?
After my last post, last night, my mind kept on-going, I thought! Again WHAT IF? You’re right Paul Herrin, “It's not about how many tracks you can fit in a simultaneous stream... it's about light filtering.” HOWEVER it’s also an important consideration, you need to record the IMAGE.
The Technicolor image was develop between 1916 (Process 1) 1922 (Process 2) 1928 (Process 3) and 1932 (Process 4). All the solution were “MECHANICAL”! Now it’s time for a SOFTWARE approach to the challenge of the IMAGES!
Again, I say that a solution must be found to what goes between the Camera and the Lens utilizing a Red Epic M or X Monochrome Camera. It could be a “Beam Splitter” or it could be series of filter to specific light waves to record the HDRx files onto a single R3D file. Or some sort of SOFTWARE solution that allows the HDRx files.
Here is a short quotation from the Wikipedia Page:
“SHOOTING TECHNICOLOR FOOTAGE, 1932–1955” http://en.wikipedia.org/wiki/Technicolor
“Technicolor's advantage over most early natural-color processes was that it was a subtractive synthesis rather than an additive one. Technicolor prints could run on any projector; unlike other additive processes, it could represent colors clearly without any special projection equipment or techniques. More importantly, Technicolor held the best balance between a quality image and speed of printing, compared to other subtractive systems of the time.
The Technicolor Process 4 used colored filters, a beam splitter made from a thinly coated mirror inside a split-cube prism, and three strips of black-and-white film (hence the "three-strip" designation). The beam splitter allowed ⅓ of the light to shine through a green filter onto one strip of film, capturing the green part of the image. The other ⅔ was reflected sideways by the mirror and passed through a magenta filter, to remove any green (which would have been redundant). The diverted non-green light exposed a pair of film strips spooled together; one which captured only blues, itself a filter, and another which picked up whatever was left (the red part of the image). The "blue" strip could act as a filter because it was a special type of film known as orthochromatic, which is designed to absorb some light frequencies and not others. The "green" and "red" strips were both of the broad-spectrum, panchromatic type.
To print the film, each colored strip had a print struck from it onto a light sensitive piece of gelatin film. When processed, "dark" portions of the film hardened, and light areas were washed away. The gelatin film strip was then soaked with a dye complementary to the color recorded by the film: cyan for red, magenta for green, and yellow for blue (see also: CMYK color model for a technical discussion of color printing).
A single clear strip of black-and-white film with the soundtrack and frame lines printed in advance was first treated with a mordant solution and then brought into contact with each of the three dye-loaded printing strips in turn, building up the complete color image. Each dye was absorbed, or imbibed, by the gelatin coating on the receiving strip rather than simply deposited onto its surface, hence the term "dye imbibition". Strictly speaking, this is a mechanical printing process, very loosely comparable to offset printing or lithography, and not a photographic one, as the actual printing does not involve a chemical change caused by exposure to light.
In the early days of the process, the un-exposed blank receiver film would be pre-exposed with a 50% black-and-white image derived from the green strip, the so-called Key, or K, record. This process was used largely to cover up fine edges in the picture where colors would mix unrealistically (also known as fringing). This additional black increased the contrast of the final print and concealed any fringing. However, overall colorfulness was compromised as a result. In 1944, Technicolor had improved the process to make up for these shortcomings and the K record was, therefore, eliminated.”
As you can tell most of the process was done in POST! Only the recording needed the THREE STRIPE PROCESS. So the only “CHALLENGE-IS”, what goes in the middle, between the Camera & Lens, in B&W; Software or Hardware? In 1932 we were dealing with an ASA of FIVE (5), yes Five, today we have 2000, quite a difference, thanks to Red. All in the Monochromatic space!
Humberto Rivera
It’s a Monochromatic sensor, it’s got a high ASA/ISO (2000), it’s got good Dynamic Range, and it gives a clean image! Now THE CHALLENGE, how do you record different wavelength onto one sensor? You already worked out the Monochromatic Sensor, how to record HDRx, high ASA/ISO, you now need to figure out how to split the light coming through the lens, before it gets to the monochromatic sensor! It’s no small challenge, but nothing is impossible, it’s that they haven’t found the solution, YET! I’m just posting the question; WHAT IF? We would then have a Camera capable of recording “Three Stripes Colors” on a single devise, which would definitely be a GREAT THING!
Humberto Rivera
I do not understand the myopic response from a number of people on this thread to this amazing addition to the RED family. I wish I could afford one now.
I remember that. I think Brook posted a picture of the see-through Oakleys.
