How do you clean the dust from the OLPF on Epic and Scarlet ?
Non Contact methods first, i.e. Rocket blower
Others have recommended brushed such as the Arctic Butterfly.
AFAIK, RED has recommended the Arctic Butterfly too.
The butterfly uses static electricity to attract the dust away from the olpf.
Ideally it does not touch the glass. If you have really stubborn dust particles the light brush can dislodge them.
I would not use those Rocket Blower things, all they do is empty small bits of rubber from the hand pump on to your sensor or lens to which it then sticks.
I noticed that B&H has MANY models of Arctic Butterfly available.
Any suggestions?
Do you really touch the sensor when using that Arctic Butterfly brush? Doesn't it leave scratches?
You never touch the *sensor*. You physically can't touch the sensor. All you're touching is the OLPF, which is like an optical flat in front of the sensor itself.
Mike
anything you do needs to be very gentle and carefully done.
turn it upside down and 'blow' the dust out, preferably with something professional. don't know about the rubber blowers. always best to be safe with this kind of stuff.
otherwise, checkout the butterfly.
Whatever you do, don't use 'canned' air. It can be cold and crack the glass.
I found that if you use an almost empty can, it is safer, but I would not recommend it.
This is not the kit I have but this is a great basic kit to get:
http://tinyurl.com/8md8wke
You'll want the loupe. Why even try to understand what needs cleaning if you're not really getting a good view of the OLPF.
My kit has a other extra brushes that I don't use. I have swabbed the OLPF plenty of times while in the field. Sometimes it's better to do that than let some hard to remove tiny junk sit there. Especially past T11.
Another +1 for the Arctic Butterfly. I also recommend compressed Nitrogen if you have access to it.
broken link :(
Stu Aull
Alaska
