Carl Dieker
Yeah, pretty much like the title says:
OConnor CFF-1 vs Arri FF-5
Any opinions?
Any opinions?
Any opions?
Yes, the CFF1 looks great, very, very modular, but not so good if "gears loosen after using it very much", as Kemalettin writes. Anyone else had this problem with the CFF1?
I think Arri makes two versions of FF-5 and the one with the longer swing arm is FF-5 HD. FF-5 Cine has a shorter swing arm. Both FF-5 and CFF-1 are the best follow focus systems available right now but I chose CFF-1 since I can easily adapt it to LWS, 15mm Studio or centered, and 19mm studio rod system and 15mm & 19mm studio use same bracket so I don't need to buy another rod adapter.I've heard from several sources that the FF-5 has a much longer swing arm that makes it difficult, usually impossible, to position the arm/gear beneath the lens.
I've heard from several sources that the FF-5 has a much longer swing arm that makes it difficult, usually impossible, to position the arm/gear beneath the lens. This blocks the witness marks for focal distance. For good reason, your AC should be able to work with the witness marks on the lens. A talented AC over the age of 22 will have learned to pull focus using marks and the lens distance witness marks--as opposed to hunting with a monitor.
FF4 FTW
Love our CFF-1 package....
Now one question: Is there a a focus gear (about 32sprockets) that I can by that is longer.. We have the problem with our new hawks that when going from infinity to close focus the lenses move so much so the gears does not line up. So I need gear wheels that are longer / thicker or what you would call them... I would like it to be almost 2 cm thick... i think O'Connor does not have such gear. Would love to get a working solution asap since this kit is going to be rented rather soon.
