R3D Metadata spec
mfuhlendorf
New member
44
Is it possible to read the red clip metadata directly?
I mean, open the R3D files directly using PHP, for example, and read the file header with all the metadata? The idea is to write a web interface software to sort RED files on set before sending them out to the editor.
Thanks in advance
Sure. As long as you have REDLINE installed on the computer. If you launch Redcine Pro (download from RED website) - under HELP there's an option to install REDline as well as a complete guide to how to use REDline under the HELP menu - example:
1. Launch REDLINE. Refer to LAUNCHING REDLINE.
2. Create a destination folder that your modified files will be saved to.
3. In the command line type:
”redline --i /Users/user.name/Desktop/A014_C001_0209H8_002.R3D --outDir /Users/user.name/Desktop/test -o test_file --printMeta 2”.
Or if you don't want to interface with Redline and you're writing your own web interface plugin, all the tools to query metadata are in the SDK. It's pretty straight-forward. One of the code samples does exactly that, pulls all the metadata entries from the target R3D file.
Thanks!
I'd never used redline before, it does EXACTLY what I need.
I can't solve an issue though:
I'm using Applescript to interface with Redline; I wanted to get the metadata off the shell command return value, like this:
SET variableX TO (DO SHELL SCRIPT " redline --i /Users/user.name/Desktop/A014_C001_0209H8_002.R3D --outDir /Users/user.name/Desktop/test -o test_file --printMeta 2 " )
And it always just freezes the script, even though the redline command above works perfectly in a terminal window. I have no idea why.
Any thoughts?
To make sure applescript gets the output from the REDLine shell script command, you need to add "2>&1" at the end of the do shell script command and enclose the command itself inside a "try /on error / end try" statement. HTH
try
do shell script "redline --i /Users/user.name/Desktop/A014_C001_0209H8_002.R3D --outDir /Users/user.name/Desktop/test -o test_file --printMeta 2 2>&1"
on error errMsg
set variableX to errMsg
end try
Thanks!
I'll try that later today and report back if it works.
I'm still learning (and learning to hate) the Applescript syntax.
Thanks for all the help, I got exactly what I wanted from Redline and now I'm gonna work with it in PHP.
One more question regarding redline: is there any way to export TIFF images without an exact frame number? For example, if I wanted to export the first, last and middle frames from each clip, regardless of duration, is that possible without previous knowledge of the clip length?
Thanks!
