Camera Firmware + RCX Pro Build 13 beta (includes RED player and Photoshop Plugin )
Jarred Land
Fire Chief
Staff member
Releases tonight if you stay up long enough :)
New in RCX Build 13:
RED PLAYER - Stand alone player for R3D files. Rocket enabled. Allows quick and simple single window playback of R3D files.
R3D Photoshop Plugin - You gotta see this one...
Camera Firmware:
New Autofocus Algorithms
Fixed duplicated columns in 5K playback
Changed PL Lens auto-detect feature to DISABLED
Removed "INTERNAL" sync option
Fix for record freeze with saturated image
Fix to disable DC jack reads if an error occurs during reading
Fixed 2K format Histogram clipping issue
Fixed REDmote drop down height of one element
Fixed notification for HDRx warning during cal
Fixed black shading problems at non-default exposure times
Fixed camera status information to reflect correct gamma curve
Fixed code to disable RAW button during record
Fixed invalid OSD when lens data changes
Fixed presets to enable menus on HD-SDI monitors
Fixed led indicators for the rear battery status
Fixed frame rate indicator in side handle display
Fixed raw exposure meters to match raw exposure view
Fixed overflow when calculating raw clip levels
Fixed drop downs so artifacts are not left on screen
Fixed hang in UI when using keyboard entry
Fixed code for faster PL mount lens data updates
Changed Media UI to add media percentage and number of clips on media
Changed Media UI to add cancel button to the media format and secure format
Changed F-Stop advanced UI to add lens auto-detect enable/disabled feature (PL only)
Changed Eject and Format buttons in format dialog
Changed Monitor Control UI to add non-standard frame rates for HD-SDI 720p, UI is available for non-standard rates
Added SMPTE 352 payloads for 720p
Added save mount type when lens is disconnected
Disabled OSD for HD-SDI 720p > 30fps
nice, RCX just get's better and better. Keep em coming!
Dude. Red Player = Awesome. Playlist I assume?
This plugin..... May make my head explode if it does what I think it does!
Morning here. I'll be up and waiting to dig into this! :)
Hey Jarred, I think you posted the wrong release notes, bud :)
The fix list looks rather for camera firmware than for RCX ???
RED Player sound great, and Rocket enabled.
Morning here in the UK - will be testing all day then :))
Holly sh*t-tickles! Red Player??? This is exactly what I wanted to see in Redcine-X... how did you know? You guys are on fire, try not to reveal everything in one go, you might break the internet
