There are many users new to the RED cameras who have concerns about noise and softness that are solvable by implementing a good workflow.
This will hopefully end up being a comprehensive list that I (or someone with more skills in this area like Graeme Nattress?) can edit with additional suggestions and flesh out.
My initial suggestions are meant as a starting point for users new to the RED workflow, which involves preparation before shooting as well as post production.
I'd love it if someone at RED wanted to take this over and make it a sticky. A sticky on Black Shading would also be very useful.
Potential RED users visit these forums - and they see all these threads about noise and softness and other issues that are really caused by poor workflow.
If there were 'official' sticky threads on the 'correct' workflows from RED, these potential purchasers wouldn't see these threads from people confused about the basics of using RED cameras - they would see more threads about refining successful techniques and getting great images. Everybody wins.
----- Before Shooting ------
1. Black shade at the shutter speed and temperature you will shoot. ISO, format and frames per second do not affect the black shade process. Proper Black Shading will minimize noise.
Be sure to warm the sensor up to operating temperature before Black Shading.
The first temperature readout in the bottom status bar is the sensor temperature.
A good tip for checking whether or not to run black shading is this:
a. Let the camera come up to temperature
b. Put a lens cap on the camera for a nice flat black field
c. Crank the ISO to 12800
If you observe a nice flat field image, your calibration is good and you don't need to black shade.
A deviation of only 5 to 10 degrees in sensor may affect your noise levels.
Fan speed will affect sensor temperature.
2. purchase high quality glass and filters. A soft lens will result in soft images - and every additional filter affects the image to some degree. A lens is sharpest 3 stops above wide open.
3. Possibly set Back Focus for your lens? (actually, only a professional should do this. The basic steps are outlined here for RED's earlier camera: http://www.youtube.com/watch?v=0jW9e2H_-Bk ) This will affect whether focus at infinity is valid and whether the distance markings on the lens are valid but will not affect your ability to focus.
----- During Shooting ------
1. verify that camera temperature is close to temperature of last black shade. A 5 or 10 degree difference will affect noise levels to some degree.
2. verify focus. The infinity mark may not actually be focused at infinity. See Back Focus above.
3. verify enough Light. Under-exposed scenes = more noise. Even the blacks need light to avoid noise. You can crush them later in post. The author of the following post has several other interesting posts in this thread on noise levels http://www.reduser.net/forum/showth...e-and-Softness&p=990426&viewfull=1#post990426
4. Expose to the right. http://www.luminous-landscape.com/tutorials/optimizing_exposure.shtml
5. Use the exposure tools in the RED camera
http://www.red.com/learn/red-101/exposure-with-red-cameras
http://www.reduser.net/forum/showth...Share-your-methods-please&highlight=practices
6. Be aware of the type of lighting. Tungsten lighting is noisy as it has very little blue as the blue and red channels only have 1/2 as many pixels as the green channel. This can result in clipping in the red channel. A CTB gel converts tungsten light of 3200K to 'daylight' color.
http://en.wikipedia.org/wiki/Color_correction
7. White Balance (easiest do do while shooting. Graeme prefers to white balance off a neutral gray card to not pick up reflected light)
Note: there's an advanced menu to calculate white balance, and several ways to get to it:
Touch and hold the Kelvin menu with the touch screen or scroll to the Kelvin window with the Side Handle and press the 'up' key.
In this menu, you can set Kelvin and Tint manually and "Calc White Balance".
8. Stabilize the camera from vibration.
9. Shoot 800 to preserve highlights. If you regularly use a light meter on all the areas of the shot, shoot 320
10. Higher compression can make your video seem less noisy as noise gets compressed away, but it will also have less detail. A very 'busy' scene will need lower compression to preserve detail.
11. The native color temperature of the Mysterium X sensor is 5000 Kelvin. Try to shoot between 5000-5600K by using filtration on the camera or on the light source, especially when shooting tungsten. Shooting outside of this range could result in more noise.
http://www.reduser.net/forum/showth...e-and-Softness&p=985127&viewfull=1#post985127
http://www.reduser.net/forum/showth...e-and-Softness&p=985146&viewfull=1#post985146
12. To avoid fan noise, try 35% manual for recording as a starting point (depending on ambient temperature). Standby speed will be higher, but ... it's unclear if a very high standby fan will reduce the temperature so much that your shooting temperature will differ from the black shade temperature and thus introduce noise. So, having a standby less than 100% might be advisable. The goal should be a stable temperature where the fan doesn't kick on 100% during recording (as it will if it reaches a certain internal temperature).
----- Post Production -----
1. R3D files have no sharpening applied. They will look 'soft' without sharpening.
2. R3D files have not been de-noised. NeatVideo.com is perfect for this - which can also sharpen.
3. The result may an image that looks very different from when the same lens is used on your DSLR. This is normal. Those DSLR images have been sharpened and de-noised to some degree. With R3D files, all the magic happens in post.
4. Be sure to view the image at (1:1) 100% to judge. Also be aware of your de-bayer settings.
http://www.reduser.net/forum/showth...e-and-Softness&p=986625&viewfull=1#post986625
5. Set White Balance BEFORE converting to RGB space for grading
http://www.reduser.net/forum/showthread.php?40067-Thoughts-and-Tips&p=539836&viewfull=1#post539836
6. The bayer pattern sensor used in RED cameras means that if you shoot at 4K, you get 4K * 80% = 3.2K of actual resolution. If you look at 4K blown up at 100% and are unhappy, try looking at it at 80%.
Check these two links to understand Bayer patterns:
http://www.reduser.net/forum/showthread.php?40067-Thoughts-and-Tips&p=539848&viewfull=1#post539848
http://magazine.creativecow.net/article/the-truth-about-2k-4k-the-future-of-pixels
Remember that even though 4K yields 3.2K of actual resolution, 'The Girl with the Dragon Tattoo' was shot in both 4K and 5K on the RED. 4K after processing will still be good enough for a movie projected at 4K, as was the Dragon Tattoo - and will be superb when down-rezzed to 1080p, which is the reality for those of us not making a feature movie.
