Mohamed Younis
I have a vmount plate and I want to install a lemo wire in it.
I wish I could but I really need it for a shoot urgently and I'm in Egypt. I have the 4 pin lemo to flying lead. I'm not sure if that helps though. I can use any cable even if i have to cut it but I just need this ASAP.Send it over and we'll take care of it![]()
Can I cut the wire from my DC adapter and use that?user manual page 171,
i re wired my pilot, but if you're not confident get a technician to do this for you;
Mohamed,
I am not sure how/if my pictures will help you, but sure
I bought an XLR cable just for that, cut the XLR jack, black and white go to ground, green and red to +,
carefully just cut thin data cables , can't remember the color, but they are very thin, if you are going to use power adapter, cables color could be different, so just test them,
if you have foggy idea how to, please don't do that, just hire technician,
best.
both, cuz they go to pin 4 and 5 on lemo, there shouldn't be two ground cables in your V lock plate;
and also + contact on V lock - both wires from pins 1 and 2,
whatever color they might be, must check with diagram from manual.
it's easy, it's plus and ground, that's it, but if you do it wrong
I learned it hard way, it cost me $1200 power board on my EX1, on your epic it'll cost you a bit more, so think twice
just don't mix the polarity;
