Niko Pueringer
First shoot with the Scarlet today. Been waiting a long time for this.
Some stills (light grade in Redcine):
Hi Niko,
What handles (brown) / grips are you using?
Thanks Hiroe
Hi Niko,
Thanks Hiroe
Niko, pics look great. I'm guessing Corridor Digital movies are getting upgraded!? Been a fan for a while. Keep it up!
Niko, do you have a close up to see how you mounted the two Wooden Camera handles and the LCD ?
Hi Niko,
Stills look great. You have the "exact" same WC handle/config I've got on. (Though I went for the cheaper black rubber) However I'm still waiting on my touch to shoot, so would love some feed back form you.
* Can I ask what plate you have on top. Easy top x/plate?
* Hard to see, but looks like you have a side handle on already as well - can I ask are you holding Scarlet a little out in front so you can have the LCD at a perhaps more reasonable distance? (I've seen a few Epic rigs push the LCD further up out over the lens) If you are holding her with arms a little extended than that naturally strong and stable "elbows in" position, how has the weight/stability felt? I've been considering this a lot and I'm thinking of rigging the WC side handle diagonal out the front and then adding another side handle left rear to get that machine gun hold feel for strength and stability, and also to put the LCD a little further away.
* How are you finding the off set with LCD in genera? Most people seem to rig their touches straight in front.
* Are you running with the 7" cable? How maxed out is it with the LCD side mounted where it is? Don't suppose you still have another couple of inches of play?
* Also just wondering what lens the stills were shot on?
