PRODUCT REQUEST: 15mm Lightweight support on Epic mounting Plate instead of Baseplate
Yep. This is the most urgently needed accessory. The QR system works well, but it is incomplete without being able to switch between Studio rods on the baseplate and then immediately break away with LW 15 rods. C'mon RED (or Brook)!
It is indeed needed badly! Hope someone (Red, Viewfactor or ActionProducts) releases one real soon.
any word on this? I see the 15mm version in the store, but it's not in stock... curious about availability? Also is there a solution for mounting 15mm rods on top?
Is this product still in the works? (Lightweight 15mm Epic QR plate, so you can release with 15mm rods still attached.) Or did anyone else out there come up with an alternative that works with the Red QR system?
mitch
you mean like this...
Viewfactor also has the FMJ bottom plate and 15mm bracket. I just ordered those after using a friend's... they're fantastic (and in stock!)
Bummed to have had to cancel my order for RED's modular assault plate pack but I had no other choice.
