Stacey Spears
- Sep 15, 2007
- Age
- 56
- Sammamish, WA
- www.spearsandmunsil.com
I have the Formatt Hot Mirror / ND filters. They were $135 ea for 77mm.
Literally ordered two of those today Stacey. I will be purchasing the Schneider Platinum IRNDs around March/April for use on a feature, but I'll need something better than my normal NDs for the next few months as they have way too much IR contamination.
Would you recommend these to begin? I'll be using them for narrative work. Should I got with .6 and .9 or .6 and 1.2?
Thanks!
Tough question and one I'm still answering myself. I'll likely be testing out a ton of these, but based on the previous tests the Schneider Platinum IRND seem to be the best choice if you are concerned about quality. However, I can't buy those today as the 77mm filters aren't even being manufactured until the end of the 1st quarter of 2012. Hard to wait that long in my case.
I'll be testing out the Formatt filters once my Scarlet arrives and I'll share the results. I picked up a 0.9 (3 stop) and a 1.8 (6 stop). The main reason for just those two is to see how they hold up at stronger filtration levels. In my experience many ND solutions really go screwy past 1.2.
Filter selection and range is a personal choice. I know I can solve many 1 to 2 stop variations in camera, with set lighting, or in post based on my experience, hence the .9. The 1.8 I choose is to attempt wide aperture work in natural light and on set.
If I fall in love with these, I'll probably buy the full range though.
The reason I'm going with 77mm rounds is out of my now 43 still lenses only two of those have larger than 77mm filter threads. I like to stay compact and I enjoy shooting without a matte box a lot. However, when using rental cinema glass I'll be renting a matte box and filters to accommodate their larger diameters.
Also, I have aerial shoots lined up this year and spring next year and there's no chance in hell I'll be playing around with matte boxes and filter trays when the helicopter's door is open. Otherwise somebody walking around Los Angeles could end up with a glass filter stuck in their head.
Thank you for your response Phil. Very insightful. If the platinum's are that good then I'll spend a little extra $ and buy them. They have the 4x4's on sale for $235 at film tools.
Hey guys, just a confusion set in from probably over researching this, are IRND/Hot Mirrors recommended for Epic too? some of the research led me to think it's really only needed for the scarlet..
just looking for clarification
I agree with this.Just a work of advice.
Any IRND filter should be tested with the camera you intend to use it with. Not all cameras have the same filtration in their OLPF and thus not every brand of IRND filters the same wavelength of light.
Each IRND should be tested with the specific camera/sensor combination.
Battistella
Color shifts are fixable. What isn't fixable is the horrifying ghosts that some ND filters have been shown to impart when using certain lenses. This was a serious, serious problem with our first film and the use of Pancro mirror NDs. There was a very subtle, but clearly visible ghost on these shots, and many other people using DSLR lenses found the same thing. Worse, the effect was pretty subtle on set, and in the heat of the moment, no one saw it. BUT, once we got into post, there it was. . . a ghosted shift of about a foot or two in real-space. You may not have a ghost using cinema lenses, but we found that Formatt IR+ND filters NEVER caused a problem with ghosting, even in the worst conditions.
Agreed. Though I will say outside of the Firecrest Filters, it's a SOB trying to get filters in the 0.3-2.7 ND range that are reasonably matched. Luckily I don't really even have to deal with that anymore.
Phil,
I was looking at these at B&H
http://www.bhphotovideo.com/c/product/764280-REG/Tiffen_W4565PROKT_The_Pro_HV_Filter.html
Are they any good for good old ND? Purchased the Dragon upgrade so not IR....Yea!.
