has anyone put a canon 17-55mm f2.8 on an epic to see if it vignettes?
We can't get the best results using still photography lens. I'm assuming Canon mount as great but temporary solution anyway which is , meanwhile, needs to be replaced with PL. Unless you have planes to buy a new Canon cine lenses with EF-mount (which is could be excellent choice, by the way). This is why I am Not going to expand my current EF-mount inventory.
And I'm agreed with Claus - If you already have something like 24-70/700-200 !L! and couple primes you are good to go!
would love to know the answer to this too
So, the Scarlet-X package is quite a bit more than I had anticipated, but it's also a vastly superior Scarlet. But no lens included :/
Can anyone recommend a few inexpensive lenses that are compatible with the Canon EF mount that would be considered essentials?
Will the lack of IS on the EF 24 - 70mm be of any concern? It will be my only lens for the first couple months![]()
ditto. Just bought it yesterday, can't wait to fire it up on my scarlet. Thinking of picking up the canon 8-16 L to cover the ultrawide stuff, anyone shot it on the Epic?
When you use an APS-C lens are the focal lengths (in terms of field of view) relative to a full frame camera still? What I mean by this is that if you have an APS-C 10-22mm lens will it still be 10-22mm at 4k on the Red (which, as I understand it has the same crop factor, 1.6x, as an APS-C camera)? Or would the same crop factor still apply, making the field of view more similar to a 16-35mm full frame lens?That's a fisheye lens. You might take that into consideration- heavy distortion! Maybe a Canon 10-22 would suit this better...it's the widest you can get on aps-c. If my memory doesn't fail me...
The new 70-200mm IS II is sick on the Epic.
