Hi everyone,
Im new to the cinema lens world. So I have 3 Lomo Anamorphic lenses. 2 Squarefront (35mm + 80mm) and 1 Roundfront (50mm) that I want to place into a Pelicase.
How would you guys make the layout for the lenses in the case.
Would you place the heaviest lens in the bottom part ? Since it is a carry on / trolly, the case will be in vertical position a lot.
Im not sure if the foam is strong enough or if it even makes a difference. I know it might seem a stupid question to some of the more experienced here in the forum.
But better be safe then sorry
So the question is: What is the best way to layout the foam? also good to know would be how to cut the foam best?
Here is the case I will be using
http://www.bhphotovideo.com/c/product/330231-REG/Pelican_1510_000_110_1510_Carry_On_Case.html
Thanks everyone,
Eric
Thanks everyone,
Eric
