New EPIC-M firmware build 1.6.12
Hey guys,
Any tips for me here.. RCX 470 works well on my laptop,
but on my 12 core. through the RED ROCKET I cannot view the 300fps stuff. ?
Obviously a RED ROCKET update issue...
Any new rocket firmware I should be aware of for the 2k 300fps. ?
thanks anyone.
Hey guys,
thanks anyone.
It was in the email I sent you last night.
We've been testing the new Firmware for the Epic-M.
It is still a little buggie:
*Lots of freezes
*Preview monitors went green
*At one point, monitor went B&W
Overall though the footage looked good, and there has been no issues with recording. We have been very happy with the 300fps.
We've been waiting on the REDmote update sense you can't roll back, and wanted to know if there have been any bugs that you all have noticed with it's new build?
Stephen Wheeler
Rental Tech
Daufenbach Camera
Specializing in RED, Digital Cinema, & 3D
www.daufenbachcamera.com
That sounds like the lcd/evf cable is bad or loose.
I've not noticed those problems but:
Once a "split screen effect"
3 power peak shut down yesterday with this build (more or less like the previous build).
I miss the matrix focus control. I shoot every thing handheld doing myself the focus. This focus mode is essential... strange how fast we get used to be spoiled ;-)
I would love to have an option to flip the monitoring upside down so I can fix the touchscreen LCD the way around...
I can't imagine the day I'll have to shoot with another camera...! Heartbreaking. :-)
Patrick
I had my LCD go totally red hue....and split screen and some strange other effects. So it's back to RED for evaluation. tested other cables and my older RED ONE monitor---all worked flawlessly. I think something was coming out of contact on the touchscreen LCD---pressure on back of it would compound OR alleviate the problem. Anyway, now with a new touchscreen LCD and no issues at all.... New build seems to be quite a bit stabler. Only thing that seems a bit "touchy" is the touchscreen itself--this may be that each LCD has it's own issues or feel. BUt i have to touch 2-3 times to get functions to open up etc....I get frustrated in some places and then resort to the REDMOTE which works great. But would be nice if the touchscreen was a bit more sensitive like on the iphone or android.
I have had split screen issues as well. None if it actually was in the recording.
The edges of a touch screen are usually less sensitive than the rest. This is where many people place menus too. Apple spends a great deal of money for the quality of touch panels they use in the iPhone, iPod touch, and iPad to get uniform performance. I have been using a capacitive stylus and feel I get better results on the menus across the top vs. my finger. Don't see much improvement on some of the menus where you have to scroll.
The focus control was never very accurate for me. I tried the circle, matrix, and center square. (I don't recall the actual names off hand)
On the subject of focus, I used to always use the focus view on the RED ONE where the image went B&W and edges, in focus, where highlighted in RED. When they switched to blue, it never really worked for me. Its back to RED, on EPIC, but still not working well for me. It seems like the edges need to be either brighter, thicker, or both.
Mark,
If on MAC make sure you use the built in OSX "Archive Utility" (right click -> open with) on the zip archive.
apparently the terminal file(s) doesn't like to be unzipped with anything but that.
Jason
My jaw dropped when I shot 120fps with HDRx in 2K.
The REDMOTE is crazy now - super fast and easy to change ANY setting, including adjustments to color - wirelessly.
This build is a whole new camera.
Actually, my jaw almost dropped. Brook Willard was recording Mark and I standing there at 120 FPS in HDRX and as I turned around, Mark swung at my face, and in slow mo you can see the exact moment where I realized he was going to hit me :) Good thing I have cat like reflexes and dodged it.
Post footages please - Lim
For those Epic owners, with the Redmote becoming faster and easier to use do you find yourself still using the touchscreen much?
Cheers
Paul
Cheers
Paul
I no longer use the Touch screen, and very haply so, as it stays very clean, was already using the same touchPen I use with the iPAd, but now the Redmote is insanely good... ;)
We have an anamorphic shoot this weekend and next weekend where we'll be hammering on this build in a production environment.
This is only after LOTS of testing on prior builds. Testing is key.
Jason
Jason, have you had any luck transcoding the anamorphic footage in RedCine-X?
good to hear. what specifically is different?
Tom, hope by now you've tried the new firmware for the redmote. I actually get a connection now and the ease of the layout is about all i can say. You'll see it soon enough. But before i was stumbling through the menu and connections were terrible.
Where is the link for this firmware? I need to send it to a fellow epic owner.
I just noticed a couple bugs in my Side Handle display.... settings not updating with the dial movement (though updating on touchscreen). I jumped to the beta firmware 1.7.9 to get HDMI out. Should I do the 1.6.44 to upgrade Side Handle FW then move up to 1.7.9? Does the Camera FW automatically update the Side handle when it's attached to the body?
