Manuel G
- Mar 25, 2011
Where is the line to pick a number to Epic -S
?...It´s possible to plug a Canon EF mount in Epic- S like X series ?
Best regards
Best regards
As for the fps discussion - it seems all geared toward 24fps film and 30fps stuff with multipliers (48/60) - I am in HDPAL land most productions go to TV :/ will we have 25/50 fps options on the epics (scarlets)?
Where is the line to pick a number to Epic -S?...It´s possible to plug a Canon EF mount in Epic- S like X series ?
EPIC-S and Scarlet share code base with EPIC-X, meaning they run essentially the same software, so we can just read the manual RED has published:
Project timebase can be set to 23.98, 24, 25, 29.97, 48, 50, 59.94 fps; If you want to go away from that, VARISPEED, you can change it in 1 FPS increments from 1 fps to the maximum allowed by the current resolution / redcode combination.
So no issues whatsoever for us PAL folks.
Where is the line to pick a number to Epic -S![]()
My bet is 5K at 60fps at REDCODE 6:1. But I could be wrong...
Jim
I expect the EPIC-S to be in the $12-$13K range.
Jim
