Julio Quintana
- Apr 25, 2007
- Austin, TX
- www.juliomquintana.com
As for a 14 or 18mm I'm perfectly happy with the 14-24, at those wide focal lengths 2.8 is fine for me.
I'm actually the opposite. It's relatively easy to get light levels up for tighter shots in the 50-100mm range since you usually see less of the location and you can always just walk your lights in. My challenge is often getting enough exposure for the wider shots since it takes a lot of light to illuminate larger areas.
