Neil Oakshott
New member
- Oct 3, 2010
I`m not entirely surprised that this happened but I was filming with the RED yesterday using a SMALL HD monitor, and for the first time a camwave transmitter and m-one/bartech wireless focus system all off a RED ONE with one battery and the RED kept shutting down.
The camwave was bridging the RED battery and the monitor and m-one were using a multi D-tap plugged into the battery plate and my basic assumption is that as soon as the focus puller started the motor it drew too much power and basically shut down the RED.
Now the obvious answer I`m sure is that I should use a second battery (which we ultimately did by putting the camwave off-camera using a separate plate) but can anyone suggest an alternative that allows me to keep the whole enchilada running? Is it the d-tap that`s getting overloaded or is it simply too much to ask of the battery? Could I run one of the accessories out of the camera?
The second obvious answer I guess it to get the dual battery plate but as you know, 2 batteries + a camwave is a fair stack to add to the camera.
Any other advice / suggestions would be greatly appreciated!
For instance, is there another power source that I could consider for the bartech ff w/ m-one motor that removes it from the camera?
