Roberto Lequeux
Jean, your dark B&W keeps catching my eye. I really like it.
It is my understanding that when you scale down, say by 50%, you also double your rounding error accuracy. Each resulting pixel is pushed through the grade's math as two distinct pixels, and the resulting values are then averaged out into one. Though I understand enough about bit-depth to know that each additional bit per value has a much larger effect than halving rounding errors when it comes to grading. I mentioned it because it does help, even if only a little, so heck I'll take it! And because it really matters a whole lot in other ways like cropping in, and more importantly sharp images without the need for sharpening.
So what did the bit-depth on Epic end up being? Is it 16-bit?
Yes. Thanks again Jarred for letting us get a taste of grading Epic with such nice images. Very generous of you.
Not sure what the size of the image has to do with dynamic range or bit depth...
Thanks. Jarred's Lighting helps a lot. :smile5:
