Steve Dent
I'm cringing at some of the grades, because Epic's ability to hold information in the highlights and shadows is creating some bad choices, although it's technically interesting to see the range that's possible
But I think Jared intended the model to look slightly sweaty and grungy (a sheen of sweat on her amazing cheekbone). That sheen is basically a highlight, but it contains enough information to basically grade it out, making her face look quite flat when it's gone. Also, you can then see every pore, so the model might be pissed.
Similarly, the shadows in the factory backdrop can be substantially reduced, thanks to the large range of black levels possible in the Epic image. However, that's a bad choice, artistically, in this case.
After removing the highlight on her face, and the shadows in the background, because, hey, we can! it starts to look like a Sears catalog image.
But that's a testament to the Epic, because you couldn't even attempt it with most other cameras. Artistically though, it screams for a contrasty look, with crushed blacks, like the original grade in the first image. But to be able to go from a flat, washed-out (sorry, boring) grade to a crunchy, dirty (great) look with the same raw file is phenomenal.
