Lee Saxon
People in the know say the lens alone is worth more than $6,000
"Worth" and "Zeiss/Cooke/etc would charge" don't exactly mean the same thing. Oh the cine market...
So I can definitely see a wide angle converter in my future... IF the optical quality is up to scratch.
And even some was done with a DSLR (not advertising for another camera here).If fixed is wide enough for you, then why not go with it. Black Swan was shot mostly with 16mm, some scenes were shot with 12mm and 20mm.
Steve Gibby has mentioned this...
RED has stated that they once were developing a wide angle converter as well as a zoom multiplier. They haven't given much word on it as of recent...but neither had they spoken about the mattebox until just this week.
If I would buy one camera only, I would never buy Fixed Scarlet. 24mm lens just isn't nearly as wide as needed with that sensor size. Of course I could buy some cheap DSLR with wide lens for wide shots, but what's the point to have Scarlet then when it's not versitable for normal shooting and you have to use crappy (compared to 3k RAW) DSLR 1080p in your work. I don't think no one would buy Epic if the widest lens possible for it were 50mm.
Oh ok, sorry my noobness. So in the wide end the lens would be the same as 15mm in s35? How about in FF35?Hi Derek. I think you may be getting confused between the actual focal length of the lens and the "relative" focal length of the lens in comparison to other formats.
The lens on the Fixed Scarlet is a 7.5mm-63mm f2.4/T2.6.
Thanks for clarifying that. I'm pretty new to the video world, but have been photographing for few years with FF. My widest lens is 16-35/2.8 and it's wide enough for everything at least for me, but there have been many times where 20mm has been the minimum focal length that I was able to get the shot just like I wanted (or at all). So that's why I think Fixed version is still not wide enough. I mean, I would be very sad with Scarlet in my hands just to realize that I'm unable to get the shot for that reason and there's nothing I can do. Photography is different field though and wider lenses are used more often, but I would want the Scarlet to be able to record every shot I wan't.No need to apologize.
Well, remember there are qualities of lenses aside from field of view that are dependent on actual focal length.
So the field of view on the wide end would be equivalent to ~20mm on S35 and ~29mm on FF35.
but for (extreme) sports it will not be enough.
Yes the difference is huge compared to FF35. I don't think the sensor size is big enough, Fixed or not. For documentary work it is ok, but for (extreme) sports it will not be enough. DSLR's would be ok for that, but then 30fps isn't enough. Fast frame rates for me is the most important thing in RED's, but the price of Scarlet S35 body will be what, 3x more than the 2/3? Maybe I should just start saving some money and buy the S35 version next year![]()
Epic-S don't have 120fps in 3k or 2k? Yes I know FF wide open is too shallow for almost anything, and for video you have to stop it down quiet a lot to get pleasent DOF, and that will cost you ISO. In my opinion S35 size sensor is way better for video.If you want Scarlet 2/3" frame rates in S35 you will need Epic-X, $28k body.
But you are thinking like a still photographer. Most broadcast action sports is shot on 2/3" or smaller format cameras. FF35mm shallow DOF is not easy to deal with following fast action. If you are shooting very wide you won't get it anyway.
