Martin Ubilluz
Maybe this had been answered but I need something solid. The MX is set to 800 ISO when you get the camera but is it still 320 ISO in RAW... If im shooting outside do I need more ND?
I got my MX today and when I switch to RAW view everything is much darker I wondering if the RAW is still 320 ISO
AND you only get that protection through reclaiming the highlights by post-processing @ a lower ISO.
Or using the latest REDcineX and outputting EXR which gives you un-clamped float.
IR = infra red.
ND = neutral Density
Haven't heard any continental differences to this...
Ryan, we are referring to filters you place in front of the camera. Not different types of sensors.
The red one is not an infrared camera, but the sensor does pick up some light in the infrared spectrum.
Placing a infrared filter in front of the camera & lens blocks light of the wavelength length to the sensor. A neutral density filter, when placed infront of a lens, cuts down the intensity of light hitting the sensor. ND's are often used if it is too bright outside to get a usable image from the sensor.
Hope that helps.
If i shoot at 800 and then in redcine put the ISO to 320 wont everything just be darker then how i shot it?
thanx justin, aware of the ND's bt not of IF's, so what image does the IF filter give to the red? sorry about the questions, just not familiar with IF? and does this work hand in hand with a specific kind of light, thanx again
