Paul Leeming
- Dec 29, 2006
- Osaka, Japan
- www.visceralpsyche.com
Hi all,
given the new info on the SSD side port option on the upcoming Epic/Scarlet cameras, I don't really see the point in even bothering with a CF module for Epic (read Epic/Scarlet if you wish).
I'd like to see, out of curiosity and for Red's purposes, how many of you plan to use CF cards with Epic given the new 1.8" SSD mag system and the limitations CF cards would entail (plus the fact Red are no longer making CF cards for Red cameras).
Personally, I think it would be better to simply offer the 1.8" SSD side port as standard, which would give Red the economies of scale to not need to charge extra for building them, and NOT have a CF option at all since it imposes so many limitations, is a dead tech according to Jarred and actually holds the system back.
So your thoughts - will you ever use a CF card with Epic or will you simply go the SSD route and never look back if it were the standard port on the Epic body?
Paul
Paul
