shashbugu
- Nov 9, 2007
very difficult to gather much from this test because of the horrible youtube compression. It's evident that there's a bit more range and resolution on the MX but it's so terribly garbled with all sorts of nasty that it's essentially useless.
Cant wait to get my Epic, and my RED MX'd! Thanks for posting!
To be honest unless your audience obsesses over subtle dynamic range cues then the 5D is all the more impressive for the price really.
MX is fantastic, but the 5D isn't bad, not at all.
I'v found plastic skin is caused by a combination of improper white balance and over exposure. In particular, over exposing the red channel will render unacceptable skin tones - unacceptable that is, unless you like the alien complexion lookI've seen nighttime 5D2 tests where the skin on actors turned to plastic because it was (necessarily) shot at high ISO, but as soon as the actor got too bright compared to the background, the skin turned to plastic.
And no, often the audience doesn't care. But we as professionals should care.
Graeme
I did some ISO testing with M-X and 1d mk III (in stills mode, as it doesn't do video) - lighting my bookshelf as dimly as I could so I could go all the way to ISO6400 on both cameras. It's obvious I wouldn't be posting this unless the M-X looked better, both in terms of noise and overall tonality.
The main problem with the Canon (and it's not just Canons that have this issue) is that they rely on analogue gain for ISO, which means if you're in pure low light you're ok enough, but if there's any kind of extended dynamic range, you're going to clip severely on the top end and eat into the images tonality, ruining skin tones and showing a low dynamic range image. With the M-X in such a situation the DR remains high and constant, giving a fantastic range of values for any colorist to deal with and a very smooth highlight rolloff as-is.
Graeme
