[FS: OPTICS] Zeiss Standard Speed T2.1 - 5 lens kit
UPDATE 22ND NOVEMBER
Lenses have been reduced to AUD $14 000 OR roughly USD $10 600 for a quick sale.
Set of vintage Zeiss Standard Speed MK1 Prime Lenses which have been adapted with a PL mount. All have been tested on 8K Epic-W and 2K Alexa Mini and only the 16 has slight vignetting on the 8k.
This lens set has the modern T* coating found on the MK2 lenses - for more info, read up on theses lenses here - http://cinematechnic.com/optics/arri_zeiss_standard_prime_f2_t21. The lenses have recently been checked on a collimator and shimmed. Witness marks have been adjusted.
All lenses are in great condition and work as they should. No significant scratches, hazing or mold. Minor surface-level scratches that you would expect on vintage lenses are present but these DO NOT affect the image in any way. The lens step-up rings have initials and serial numbers etched into them. Heavy duty case is included. I've used these only briefly, am and selling for financial reasons.
16mm T2.1
24mm T2.1
32mm T2.1
50mm T2.1
85mm T2.1
You are welcome to inspect and test them in person if you are in Melbourne.
Will post within Australia or internationally at your expense. I am happy to use an escrow service such as Escrow.com or do an EFT transfer.
Hi would you have still samples from the Epic, just never used these lenses but looking for bit of character?
Are they declicked, and will the step-up ring allow for a clip-on mattebox? what size mm fronts?
