Trotter Gollihar
- Dec 8, 2014
Zeiss CP.2 1.5/50 T* SuperSpeed EF - $3979
Zeiss CP.2 1.5/35 T* SuperSpeed EF - $3989
Zeiss CP.2 2.1/25 T* EF - $3979
These are new lenses.
Ships free UPS Ground, US only.
We also have the Interchangeable PL mount for $375.
PM or call 512-440-1400 for details.
50mm/T1.5 SuperSpeed:
T1.5 for use in low-light situations and for cinematic depth of field
Interchangeable mount
Full-frame coverage
Standard focus and iris gear positions
Compact size and low weight of 0.9 to 1.1 kg
Robust cine-style housing with the ability to utilize a follow-focus system
35mm/T1.5 SuperSpeed:
Aperture: T 1.5 to T 22
Interchangeable Mount
Close Focus: 0.3 m / 12'' (distance is measured from the image plane)
Front diameter: 114 mm / 4.5''
Weight: 1.1 kg / 2.4 lbs
AOV: 39° [Horizontal angle of view for an ANSI Super 35 Silent camera aperture (aspect ratio 1:1.33, dimensions 24.9 mm x 18.7 mm / 0.98“ x 0.74“)]
25mm/T2.1:
Full frame coverage (CP.2 18mm only APS-H)
Robust cine style housing with the ability to utilize follow-focus
Five different mounts available (PL, EF, F, E and MFT mount)
Consistent front diameter (except of 50 Macro)
Longer focus rotation and a manual focus and iris
Calibrated focus scales
Full-frame coverage
25mm/T2.1:
