Derrick Cohan
Just wanting to see if anyone else is having the same issue with their WC Cable-less V Mount. WC has already sent 1 replacement board to me but still having at least one of the issues:
1. The unit might work at first, however will eventually display UNKNWN time remaining / 0% on the Battery no matter how full that battery is
2. The unit will display the incorrect Battery %, and will be stuck at one number and not change
3. Battery swaps tend to trigger this error
*Using RED Weapon MG, with updated firmware.
*Unit has been used in a testing environment (quick battery swaps) and a production environment (battery is used up almost completely then swapped) - with errors happening on both situations
