Kevin J Salisbury
SOLD!!
Selling a USED Wooden Camera Quick Cage with the 15mm rod riser with top handle. The top handle is from smallrig and not a wood camera part. It is very well made and shows hardly any signs of use if any at all. It attached to the NATO rail (70mm) mounted on top. If you don't want or need the top handle, I will sell for less. Also come with a pair of 15mm rods as pictured. $689 new. The only thing different from this and the small and large versions is that vertical rod. By moving the top cheese plate down it essentially becomes the small and will work with most mirrorless or smaller dslr's. all the way up with normal sized DSLRs like D750 nikon or Canon 5D MKIV. With a battery grip you'll need the longer rod. Its the same size as a standard 15mm rod just fyi.
Located in Pasco Washington
Asking
$400 WITH top handle and nato rail
$350 WITHOUT top handle and nato rail
Buyer pays shipping. PayPal ok.
Asking
