Will SCARLET work with RED DRIVES ??
George D.
N. California, USA
If you don't use an SSD, is it possible to record the Scarlet footage on the old Red Drives? If so, what does it take to hook it up?
Is it a difficult process to change lens mounts to Nikon?
Is there any problems, WHATSOEVER, with mixing Scarlet 4K footage with Red-One 4K footage in the same production?
Thanks.
you can only use SSD's on scarlet or epic. Lens mounts are easy to switch out as 4 bolts. I mix Scarlet with epic and REDone footage all the time. Right now my Scarlet is b-cam for a epic feature.
