Why cine lenses?
Hi Sanjin,
Thanks for the discussion. I'd like to point out a few areas where I disagree with you; hope you don't mind.
1. The best still lenses have limited breathing.
"Best" means something different to everyone. I agree that some still lenses have limited breathing, but many lenses are "best" for another reason, while still suffering from breathing.
For example, the Nikon 14-24mm f/2.8 is the best (for corner CA and MTF) super wide on Still35, but I don't know if it has limited breathing or not.
2. The best still zoom lenses hold focus through zoom
Agreed. Most good lenses are parfocal (such as most, but not all, of the Canon L zooms).
4. Generally modern cine lenses are NOT sharper and DO NOT have higher contrast than still picture lenses.
A $30k Master Prime will NOT outgun any still picture lens out there.
It many areas is certainly will; especially wide angle lenses. For one thing, none of the still lenses are fast (f/1.2) and wide (14mm) at the same time. You can get f/1.4 at 24mm, or f/2.8 at 14mm, but never the two shall meet. If you need f/1.2 for thin DOF or T/1.3 for low light shooting, cine lenses are the only choice.
There are other problem with wides, too. If you use a wide angle lens designed for Still35 on Super35 format, it will necessarily have more flare than one designed for Still35. The crop factor changes what you see in the viewfinder, but light striking the lens outside of that view will still affect the whole image.
However, if your needs are limited enough that all the focal lengths and focal ratios are already covered by still lenses, then such a comparison with a $30k MP would be meaningful. Pawel says he did the comparison and found the MP performance at f/1.2 to be better than still lenses, and I'm not surprised.
But this doesn't mean that all are good in wide apertures and at all focal lengths.
You have MP 14 mm,... and when you get better please sent as here 4K Tiff file with 14mm,... @T1.3.
Then we can talk about it and discuss.
It doesn't matter what the performance is if no other equivalent lens even exists. Bicycles get better fuel economy than cars, but it's not a valid comparison because a car can do things a bicycle can't, just like the 14mm f/1.2 can do things a still lens can't.
13. Modern still lenses tend to flare much less than cine lenses.
Again, using still35 lenses on Super35 means there is a greater intrinsic propensity for flare simply due to the fact that there is over twice as much glass that is not even being used, yet still contributes to flare.
Pawel said:
15. Full frame still lenses cover larger sensor area and therefore do not perform as well as dedicated lenses designed for S35 size sensor.
All lenses are always better in center then in corners, cine or still.
Then stiil lenses can get advantge because of a crop factor from full photo still frame of 35mm to cine S35mm.
That's one of a main rules in the lens design.
Yes, but there is another, more important rule of lens design: aperture rules. It rules performance, and it rules manufacturing cost.
For example, lenses designed for camera phones have 75% MTF at 400 lp/mm! And the cost is almost nothing. The principle reason for this to be possible is that the aperture is very, very small. The incredible amount of R&D and volume manufacturing (more in one year than all still lenses ever made) are also important.
Similarly, digicam lenses have very high MTF at resolutions a DSLR lens can only dream of. And, like camera phone lenses, that much resolution is needed, because the resolution of the sensor on an area basis is so high (over 10 times greater than DSLR cameras). The manufacturing volumes and narrow aperture makes it possible for such a low price.
Unlike digicams, still 35 lenses don't *need* to be very high resolution. Still35 formats are relatively low resolution (36 sq. microns vs 3.6). If a still lens is just barely sharp enough for a 4K Still35 format, then it will be much duller on a Super35 format. That's good, because they need much wider apertures. Plus, there is a respectable manufacturing volume.
Super35 is more exacting. The performance of a lens at 6K in Still35 will be the same as its performance at 4K in Super35. 6K is about 24 MP. Many lenses perform well at 24 MP, so they will also do well at 4K.
APS-C still lenses can be made to a higher resolution than full frame still lenses for the same cost, assuming the same design and volume; however, restricting them to mount with the same flange focal length causes design constraints/compromises. For example, my Tamron 17-50 f/2.8 runs circles around the Canon 17-40 f/4 L at half the cost, and holds up very well against the 24-70 f/2.8 L.
The point is this: if everything were equal, cine lenses would be cheaper, sharper, or wider (just like APS-C lenses). But because manufacturing volume and different design constraints, the reality is that many of them are more expensive for the same level of sharpness and focal ratio.
The main reason that Zeiss made them all in T1.3 is that is easy to achieve the best lens performance
between 2.8-8 if you can start with a higher speed.
That is wrong. It is far easier (and cheaper!) to build a T/2.8 and optimize the wide open performance than to build a T/1.3 with the same level of performance. That can't be the main reason Zeiss made them T/1.3.
The Canon EF 50mm f/1.8 is $70. Stopped down to f/2.8, it has more resolution than the $400 50mm f/1.4 at f/2.8 or the $1400 50mm f/1.2 L at f/2.8. Starting with a wider focal ratio didn't help those lenses.
you may wonder if it is better to get an UP or MP or Cooke or wait for a Red Prime and get extra speed.
I don't think the focus throw could be improved much but the other mechanical factors could be. As far as comparisons the 15mm Red prime has been stated as f2.8, but it will be cheaper (Assuming $10-15K rehouse) and a UP would be fantastic but it's a prime and the 14-24 is a short zoom, perfect for crane/steadi-cam/handheld. It's real competition would come from the 16-42 Optimo Rouge. But 14mm is as 14mm does :)
Sanjin,
The MPs (from 14mm right up to 150mm) all resolved 120 lp/mm corner-to-corner with MTF of at least 15% (distinguishable) wide open at f/1.2. I am not aware of any wide angle still lens capable anywhere near that sort of performance.
The lenses around were Leica and Nikon, rehoused to PL. Also, there is plently of quantative data on still lenses at www.photozone.de and similar sites. Nothing that would encourage me to use them over good PL glass.
Of course, still picture glass is and will be used in motion picture, but more as specialty glass and certainly not for their optical or mechanical qualities.
The Leica Noctilux may be fast, but it is also rather soft wide open and its mechanics make it impossible to use it wide open for most motion picture applications. Again, if it is used in motion picture, it is as a specialty glass with inferior optical and mechanical properties.
I strongly encourage you to make an effort and make an appointment with Arri and ask them to project some of your favourite still lenses and compare them with Master Primes. It won't cost you anything. It is the best and cheapest education you can get. You will clearly see the results with your bare eyes and you can play with the projector yourself to your heart content. The differences are very obvious and clear, specially at wider angles.
For start, you will see how difficult it is to get a still lens to focus accurately and resolve anything beyond 80 lp/mm. The mechanics are simply not there for accurate focusing even on a testing bench.
Then, any 14mm still lens opened wide will make you running out the door to the nearest bank to loan you enough cash to make a deposit for a MP. Seriously.
Pawel,
where did you find that Arri/Zeiss MP 14 mm to 150 mm T*1.3 have 120 lp/mm.
Nothing like that is published at Arri or Zeiss site at all.
Then I should again call the lens expert for a help:
"Leica furnishes MTF diagrams for 5,
10, 20 and 40 line pairs or periods (10,
20, 40, 80 light/dark stripes). The more
stripes per millimeter, the finer the details
that can be reproduced.
One often wonders why the finest
structures are limited to these 40 lp/
mm. There have been articles in the
press citing lenses that can record 200
or more lines per millimeter. But now it
has become clear that the number of
lines per mm is interesting only when
stated in conjunction with the respective
contrast. At 200 lines per mm the
contrast is so low that it is virtually impossible
to distinguish anything at all.
The 40 periods used by Leica as a sensible
lower limit result in a dot size of
1/80 mm or 0.0125 mm. It is difficult to
imagine how small that dot is on a 35
mm negative! Take a negative and a
ruler calibrated in millimeters. Then subdivide
the width of one millimeter into
80 tiny individual units. That gives you
an idea of the performance capability of
today’s lenses. Once we have established
an understanding of how narrow
such a unit is, then it becomes obvious
that the smallest vibration can spoil the
entire picture. And a small amount of
unsharpness from inaccurate focusing
has a disturbingly large effect when
such small image details are important"
Quote from>>> MTF diagrams: those seductive curves!" from
"Leica-M lenses: Their soul and secrets"
by Erwin Puts
page 16
BTW, Leica always had published MTF diagrams.
Also I do not need to go in Arri Wien because I am aware of a good and a bad from still lenses.
Anyway in German speaking countries nothing is for free.
If you want to perform a certain test using Arri equipment you have to pay of course.
About banks I do not want to talk about it because they are all in big
troubles now or even flying through the black hole on the road to nowhere :clown2: .
On a projector, Sanjin.
Pawel,
I'm just curious how did you count that
according to the quote I gave you above.
"There have been articles in the
to distinguish anything at all."
LINK>>>
And now for all of us a little bit to get educated about resolution test projecting:
From "Practical Cinematography" By Paul Wheeler
From "Applied Photographic Optics" By Sidney F. Ray
7. Cine lenses have calibrated focus marks and long throw - for me
a feature that disqualifies still lenses from professional use where critical focusing at wide apertures is essential.
To get critical focus at wide apertures with cine lenses is difficult to achieve even for a caliber cinematographer like
a two times Academy Awarded Robert Richardson in Shine a Light,
live concert movie about The Rolling Stones by Martin Scorsese.
Mick Jagger in Shine a Light.
In a live shot is easy to get out of the focus even for experienced cinematographer with the best cine lenses.
Pawel,
You do it by eye. If you can just distinguish individual lines, the MTF is around 10-15% (before they blur) and this is what I could clearly see at the edges on all MPs open wide. No other wide angle lenses there could match that or even come close.
With longer lenses (over 25mm) there was no visible difference betwen UP and MP. The only practical difference was speed.
You can see 200 lp/mm in the centre of MPs "quite clearly" (with slightly more than 10% MTF) if you stop down a bit from fully opened. The biggest difficulty is to focus the damn thing to such level of detail. I can't see focusing to such small CoC in practice (and usefulness of 8k in S35 format for that matter).
Here is a good article on lens testing and MTF:
http://www.normankoren.com/Tutorials/MTF5.html
You can see the appearance of 10% MTF and 50% MTF to give you an idea what you are looking for.
David,
in a race is not that only and always winning the fastest car.
At the end a driver rules.
If you cannot get it with the beggar's tools you would not get with the emperor's either.
Pawel,
thanks for the link.
That comment has very little to do with the practical reality of shooting day after day worldwide.
Practical reality is that professionals want to use the right tools for the job that both supply the right look while being efficient to use. They will often trade one for another if and when necessary, but I don't buy the notion that practical considerations like ease of focus-pulling are not valid concerns for when choosing gear.
It's one thing to say that a good AC should be able to pull focus on any lens, and it's another thing to say that it doesn't matter what they pull focus on if they are "good enough" as focus pullers. That's nonsense. Even the best focus-pullers in the world will want to use gear that is optimized for their work.
David,
Why on earth do you keep insisting on trying to prove everyone wrong ? Several people have stated that professional expectations exceed what stills lenses can deliver most of the tme and you still want to argue the point ?
Now if you are less than a professional or commercial crew and the stakes are less demanding then sure you can use different gear to get the same result. No one's holding you ransom.
Right now I'm just about to start working on a film shooting RED. Now, i looked aroud for a while to find a rental camera. This is a low budget film and the producer's and PM kept sending me different packages with owner op's using various nikon and canon lenses.
I'm not interested in using a kit like that when I only have 18 days to shoot.
So now I'm shooting with a MORE expensive kit with ultra primes from a rental company.
I am NOT INTERESTED in using these lenses. Unless you're doing plate shots or maybe second unit and even then I woul still argue that it's not worth the trouble. Sure you can use them, but why would you want to make it harder on your crew than it already is.
I think the real difference here is that there are many owner operators that don't understand that working professionals have certain expectations. Which is fine, ebcause they put a kit together that has limitations that *they* are happy to live with. But if they expect to then rent the kit out, you can't trash your clients by saying we're film snobs wanting to shoot cine glass. Well sorry, but we're the customers and generally the way it works is you give the customers what they want and they pay accordingly.
Money is not always as important as delivery or performance. As a DP renting gear, it's my right to choose my options according to the budget I have to use and what i need to achieve for the story.
Now, I'd much rather spend more and get gear that my crew are used to working with and don't have to *work around* because it's going to make ME look bad when it's taking longer or I'm loosing performance because the gear is getting in the way of covering the shot.
There's nothing worse than having to look up from the viewfinder to say we have to go again because of the technology.
jb
Well said John. Let me know if you need a backup body or any additional gear for your shoot.
Jim
John and David, I think you nailed the essence of it. I couldn't agree more.
I would also add that in a small crew, like I am used to shoot, this is even more important. I remember my shoot at a remote reef where there was action happening all over the place. We scrambled to get the action on camera. My AC and I worked like a well-oiled machine from sunrise to sunset and using the best toys and accessories we needed for the job, just to barely pull it off. And still, a few shots missed the focus slightly despite double check with laser distance meter. I can't see how we could possibly accomplish what we needed with still camera lenses. A day of my shoot costs approximately $8k. You tell me what lenses you would use.
I don't have a problem if someone is passionate about a particular set of still camera lenses and feels that they will give him the look he wants, and is willing to work around any mechanical or logistical issues. I just have a problem when someone dismisses the problems of such an approach as irrelevant or insignificant. They are real issues to address, ease of focus-pulling on live-action.
Perhaps I can add a bit of reality to the situation as I've operated my Red with my set of Nikon still lenses but also had the pleasure of using the camera with Cine lenses. If the question is whether still lenses can be used to shoot a wide variety of content with the Red, my answer is yes. I have done it. A lot of times by myself, in situations where most would not have chose to put these lenses, even with a focus puller. But I have done it mostly out of necessity. If given the choice, I would opt for cine lenses almost every time. It's hard to deny the mechanical advantages they have over their still counterparts. I'd say the optical part can be subjective, but mechanically it's not so much.
The important thing for people who are on the fence about what kind of glass to get for their camera is to understand the situations you will be putting the camera into. If you plan to rent out to commercial or feature production with experienced crews, you can not expect they will rent your set of still lenses. Do you have to buy a set of cine lenses to get these jobs? No. In some cases, the production will rent the lenses they want, or you can rent them and package the whole deal. Owning the glass can be a nice revenue stream though and that's why you see many DPs who own their own glass. They also can have confidence in it because they own it and use it all the time.
If you will be shooting your own productions and can work within the limitations of the still lenses, they are an affordable option. You can have them modified to get a bit closer to cine style mechanics by removing aperture click stops, adding cine style gear rings, etc. They still won't have the focus range, and some of the other features of cine lenses, but it makes them more practical.
At the end of the day, the audience doesn't care what lenses were used. They care about the story being told, whether it looks good (the aesthetics, not the technical reasons why it looks good), and whether it leaves a lasting impression with them. This can be accomplished with either still lenses or cine lenses. But not understanding when to use one or the other could present problems. The last thing you'd want to do is put still lenses on a shoot where the AC is not at all comfortable with them and it affects their performance to the point where you can no longer tell a good story, the movie doesn't look good, and the only impression it leaves on the audience is that this was done by people who didn't know what they were doing.
I've been a big fan of still lenses with the Red and I stand by that because it has allowed me to work with the camera when I don't have the luxury of having cine glass. I can shoot stock footage anytime I want, I can do tests anytime I want, and I can also shoot a short film, music video, or anything else anytime I want. But when a production comes to me and wants to shoot something with a lot of complexity and a professional crew used to doing things a certain way, I have to be ready to deliver what they expect. I can't try to force my still lenses on them.
The great thing is we have options with the Red.
Thanks Steve.
Well said.
To make it clear for some posters here that I'm not against cine glass at all and that would be insane.
It was more about to be CREATIVE in a certain shooting situation.
And that sort of situation makes a great cinematographer.
Just to remind you how Janusz Kamiński, A.S.C. used Lens Baby in film Le Scaphandre et le papillon by Julian Schnabel.
I think Rodney Charters, ASC, CSC perfectly nailed to the professionals use of still glass on his RED (KIWI).
"Travels with RED" by Rodney Charters.
And of course I knew that I couldn't explain it better then Rodney.
