Stu Maschwitz
...But then film holds far more DR than a normal 4k/2k scan will capture...
Not true.
-Stu
OK, will have to do some further checking on technical data of latest film stocks. I haven't had a scanner for a couple of years now, but I was under the impression that the newer stocks were recording above the 2.046 density range that a scanner (in 10bit log) will handle... I could well be incorrect on that!Not true.
-Stu
I think many of us are used to working with log files from film (15 years for me now), but not from Redcode. My point is that when pulling down the ISO/EV to save highlights & get the data to a DI suite for the creative grade, it appears that the way Redcine works now there is still room at the lower end of the 10bit log scale to avoid compressing the black information while allowing you to get highlights in, which is the point of working in a log space in the first place. Log not only compresses the data into a smaller file, it gives more bandwith to the blacks/shadows to avoid banding issues. Thats no different to setting a film scan to set unexposed black at 0cv rather than 95 cv to give you more headroom for highlights (I've had to do this in the past to recover processing faults)but CWS, i don't actually want all the values mapped linearly - i want them to match a film response. so i'd prefer them to compress, because this is what film does - and so i'm used to it and facilities are geared for it, and well that's how film works. -
I see that as likely to be a necessary part of part of the interactive grade, and the log dpx files (0-1023) ARE the colourspace that will go to film. With Redcine/Redlog (and I presume Redline for batch processing) in its present configuration if you are willing to setup a 1-light style transfer for all footage then you'll accept that there is likely to be be some compromise for some shots, ie, highlight clipping and/or compressed blacks.... i guess the issue for me is exactly as you say, calibration for an entire film. if i'm adjusting in redcine to map all the values from 1-1024 then i'll need to at some point convert this into a colourspace that can be put to film. if each clip has been adjusted or stopped down differently to squeeze maximum range into the Redlog - then this will be difficult.
ummm, why would you want to map it to 8-bit? Unless you're using an app that doesn't handle 4:4:4 10 bit for colour work? Is that why you want to work with pdlog685?using redlog and mapping the highest white point on the neg to 1024, and then mapping this to maximum white in 8-bit space will skew all the colour values lower(depending of course on the exact log curve), or require a different curve to compress the blacks and whites back to something we'd expect to work with. it also doesn't behave like film when planning for a film out.
which is why i'm a sad panda. I just can't see why redcine has to clip it.
macka
Do you know if any of them have adjustable step sizes, and if so how do you then relate that back to 10 bit log? That would require it to recognise a (film) gamma shift, would it not?One way a film scanner is able to read density over 2.046, while still keeping at 10 bits, is by increasing the density step size from 1/500 to, say 1/465 -- in which case it will be able to read till density 2.2.
Do SMPTE specs define a DR for DPX? AFAIK, Cineon as a system is locked to the formula of 1 cv = 0.002 density, that way you can send any file to any facility and get an expected outcome on film or via calibrated viewing system. Add a variation that can't otherwise be accounted for, and it will screw what is basically a well functioning system.
REDLog is a RED designed log cruve that puts the data in a form of maximum precision and dynamic range for 10bit.
PDLog is a log curve desined to take RED Data to print density for grading or output to film. It does, however, have less precision than REDlog, as PD was designed for film, not digital.
Some places can handle REDLog just fine. For those that can't PDlog might be more to their needs / wants.
Graeme
Does anybody have a clue if RED acted in response to this -very important- thread ?
E.g. through a revision in the programming for the conversion ?
Happy New Year.
Thanks for your reply, but that doesn't really answer my question. PDLog has clipped calues above 685 which is not exactly necessary and implied by the format.
Video Deliverable
If your primary deliverable is video, then set Gamma to Rec709 and Color Space to REDspace™. Setting the Color Space to REDspace™ rather than Rec709 seems counter-intuitive; however in our tests, setting it to Rec709 gave results that were far too saturated. If the scenes were lit for ISO 320, you would find that converted images look dark. This does not necessarily mean that the images were underexposed. It does mean that you have to begin your grading session with an overall gamma boost. Use the Brightness parameter to brighten everything during the conversion process. A value of about 2.5 in Crimson is a good starting point. (The Brightness control in REDCINE™ is 10x more sensitive, so use a value of about 25.)
Another important point about the Rec709 Gamma setting is that the converted images contain all the highlight information that was captured by the camera. One might assume that using one of the log Gamma settings would export images with more highlight information, but this does not seem to be the case.
Film Deliverable
If your primary deliverable is film, we assume you will be using a print film simulation 3D-look up table (LUT) (such as from Autodesk® Lustre® Color Management) for grading. The goal is to convert your images into something resembling a Cineon®-style scan from color negative film. Because the characteristics of the RED ONE™ are so different from film negative, and because of the limited color processing flexibility of Crimson, this is not entirely possible.
To get the tone scale approximately correct, set Gamma to PDLog985. This results in images that have the correct contrast but look about two stops over exposed. Unless a shot is very underexposed, set the Exposure parameter to 2.0. This puts a normally exposed gray at a 10-bit value of about 470 (as per convention).
Set the Color Space parameter to either CameraRGB or REDspace™. Colors will seem washed out compared to film capture. To correct this, try using the Saturation parameter to boost saturation. A fair amount is needed, but going above 0.2 can start to cause clipping artifacts in saturated colors. Crimson can display the individual RGB channels. This is a good way of detecting if too much saturation boost has clamped detail in certain colors. (The Saturation control in REDline™, REDALERT!, and Crimson is zero-based rather than one-based. For REDCINE™, use 1.2.)
