Patrick Tresch
Because I want the offline editing to use images that don't look underexposed (or clipped inaccurately either), even if the final color-correction will go back to the original RAW files.
I'm not sure how the interraction between Redalert, Redcine and Redone work but isn't it possible to join to the 3rd files a LUT or a DOP predefined "Look" that would be used to develop the r3d files in the dailies?
Either in the folder containing the shooted sequence.
Or as metadata (the same type as asa setting) while recording the r3d filse.
Is what you see on the LCD, EVF or HD output allready a look you can define while shooting and store as metadata with the r3d files? Or is it a "neutral" view just for "reference"?
It would be good to have the ability to come close to what you want in final grading while shooting in the EVF. In my work the interaction between light and framing is essencial as light often makes my framing / framing makes my lightning (this more often in documentry work). Knowing when a subject is in the full dark or still in light also changes the way you frame.
See you.
Patrick
