Joshua VP
Hey guys - curious if you have noticed this issue/bug before?
If I run my Epic Weapon(powered via Vmount) and plugin an RCP Cable (from the cntrl port) into the MOVI Pro(to control the camera settings via mimic) - immediately after plugging this guy in, my menu's start lagging out super badly - to the point where the menu is almost unusable. I've been able to get around this by plugging/unplugging the RCP cable and then going into the menu. I've also noticed, that if I have this cable plugged in via startup, the Camera gets hung up on the initializing screen. Any thoughts on a way around this issue as it can be a bit of annoyance to work around like this.. I've tried switching cables and found this doesn't help..
Thanks,
JVP
Thanks,
JVP
