- Thread starter
- #21
Nathan Apffel
Trent just beat me to it.
Auto shutdown has nothing to do with the problem you are experiencing. Auto shutdown will turn the camera off after the selected amount of inactivity.
The camera will always use remaining run time or percentage reported by the battery to end roll and shutdown. The camera cannot know when a dumb battery will die.
Hi Trent. But even the dumb battery shows low voltage which turns yellow before dying. Could that not signal a timed shutdown?
I'd have to double check this - I'm out of the office today. I don't think it does since some batteries will last much longer than others after reaching a voltage threshold. Then we'd get a lot of complaints about not being able to use all the juice in a given battery.
I really wanted to correct the mis-information regarding the auto shutdown setting.
Trent,
Sorry for confusing that menu item. It's good to know that the camera auto-shuts down with intelligent batteries as a default.
Ok...so I've been running some tests and after I swapped to a second battery, now ALL my batteries show 0% and quickly switch to UNKNWN and auto shutdown in 30 sec...
I have new Switronix Hypercores, Old Switronix, and Old Globalmediapros. ALL show 0% on my Blueshape WC mount...
What do you mean? That they communicate wrong? That you have charged batteries that show up as 0%?
Fully charged batteries...now all read as 0% on my WC mount and autoshutdown in 30 sec...Batteries are fine and read about 15.2v on my VF-APU cabled mount.
Ok...so I've been running some tests and after I hotswapped using the WC dtap to lemo I got to a second battery, now ALL my batteries show 0% and quickly switch to UNKNWN and auto shutdown in 30 sec...
Granted, the error could be in the cameras firmware.
Possibly, I don't think I'm on the current release, the one before methinks. Will have to try that later today.
I see the note about hotswap power info in the newest build.
Ok so I took the plate off, booted off my cabled plate, put the plate back on and hotswapped back in. Now ALL my batteries showed up as BRICK and showed percentage. As I swapped a few more times communication eventually stopped and now all batteries are only showing voltage...me think I gotta hit up WC again...this is just too inconstant...
Jarek,
If you are still experiencing issues after your firmware update, shoot me over an email to Michael@woodencamera.com and we will help troubleshoot the issues.
You're absolutely right Trent!
BUT you could let users set in the menu their known value for their batteries.
Wait, even better 2 custom levels available:
first one (in my case 12V) for a BIG RED ON SCREEN WARNING: "LOW BATTERY",
and another voltage level (in my case 11V) where the camera would shut itself down automatically to preserve data integrity.
User could also use this to slow down the battery cells ageing process which usually occur due to discharging to very low voltages.
(for example setting these 2 values to 12.5 and 12V or 12.8V and 12.5V, obviously with reduced runtimes but batteries would be useable for some additional months/years at the end of their lifecycle)
What do you think Trent?
I think it's totally safe to include this feature disabled and then some users could enable it and take advantage of this safety feature!
I just created a thread about this here:
http://www.reduser.net/forum/showthread.php?148363
