Weapon metadata reset and fans screaming on boot up
Thomas Wallis
Brooklyn, NY
Wondering if anyone else has seen this...
With what seems like no regularity, on bootup, the Weapon will occasionally ramp the fans up as if it's doing a firmware upgrade. When it does this, all my shooting settings from the previous session are restored to factory default (5600k, 6k 2:1, etc). The other strange thing is that when I go into the camera info menu after one of these reboots, it's shows 0.1 hours on the camera, even though I've put a solid 15-20 hours onto it already.
This has happened when attached to external power, battery only, and both. I rarely boot with media attached and this has definitely happened several times without media attached, so not a case of a forgotten force upgrade folder still on a card.
Anyone have any thoughts on this? Ultimately it's not really a huge issue as far as getting the job done goes but clearly not what's supposed to be happening.
Weapon Mg
Still running on Firmware v6.2.55 as I haven't had a chance to upgrade to .57
Thomas,
I had this happen a bunch of times but I discovered it was only when I was using an older power supply for an Epic i had laying around. Something about that power supply would not let my Weapon camera shut down properly although it looked like it was. I would get the start up default reboot that you describe each time. This would include the first time i powered up on batteries. All subsequent power ups with batteries are fine. Once I took that power supply out of use i have not had that problem again. Hope that helps
Taylor
