WC UVF Mount 2 compatibility ?
Olivier Gresse
duolproductions.fr
Hi
I would like to know if the WC UVF Mount 2 can be used on the Epic-W without a top plate (so directly on the brain) or if I need to buy one?
And Is this UVF Mount can be directly used in a shoulder configuration or if I have to buy an extension or something else...
Thanks for your replies
You can certainly mount the WC UVF tube clamp directly to the brain, but you'd be interfering with the top pogo pins and/or handle start/stop interface. A top plate is most certainly recommended.
I find that the sled of the UVFv2 mount (without extension) is just long enough to move the EVF far enough forward for a balanced shoulder rig with a prime lens or compact zoom setup with a matte box. I'm using the WC Premium Shoulder Rig v2 FYI.
My current setup uses WC's pass through top plate, and I actually had to request some additional washers and longer screws from Wooden Camera so that I could mount the tube clamp on the front of the plate while still having enough clearance for the 7" in its cableless config.
I feel like there's a more elegant solution on the horizon but attached is a photo of my current setup with EVF. I didn't want to lose the cableless functionality of the cam by using lemos, so I have a WC pogo-pogo cable in play with the RED EVF mount and a nato rail clamp.
