Vinten Vision 250 Tripod with soft case
Matt Gottshalk
Potomac Falls, VA
www.mcgeedigitalmedia.com
Load Capacity 72.8 lbs (33.0kg)
Maximum Height 63.0" (203.7cm)
Maximum Height w/o Column Extended N/A
Minimum Height 26.9" (68.3cm)
Folded Length 37.1" (94.2cm)
Leveling Bubble/Illuminated Yes/Illuminated
Weight 27.1 lbs (12.3kg)
Head
Counter Balance System Continuously variable spring with digital readout
Quick Release/Wedge Plate Yes (#3364-900SP)
Balance Plate Yes, with 100mm of travel
Tilt Drag Continuously variable Thin Film drag system
Tilt Range -90 to +90°
Tilt Lock Caliper disk brakes
Pan Drag Continuously variable Thin Film drag system
Pan Range 360°
Pan Lock Caliper disk brakes
Legs
Material Aluminum alloy
Head Attachment Fitting 150mm
Leg Stages/Sections 2/3
Leg Lock Type Pozi-Loc™
Independent Leg Spread Yes
Spiked/Retractable Feet Spiked
Center Brace Mid-Level spreader
picture.php
picture.php
picture.php
Make an offer.
Tripod is located in Alexandria, VA
Thanks!
Matt
703.615.8614
