Karim D. Ghantous
Some time ago I recall reading about the Panavision Panaflasher - a light source placed in front of the lens to lift the base fog level, that works with both film and digital. It's like a low con but only for the shadows, and it leaves the mid tones and highlights effectively untouched. It's basically real-time flashing, as opposed to pre-flashing which would occasionally be done on film rolls before loading them.
I thought it sounded like a decent enough idea but didn't think of it much. That is, until I read a piece featured the DP for Little Women (2019), Yorick Le Saux:
https://www.kodak.com/AU/en/motion/Blog/Blog_Post/?contentId=4295015369
Little Women was shot on 35mm, Cooke primes and Angenieux zooms, and one of the tools Le Saux used was an ARRI Varicon:
Okay, pretty straightforward stuff... but then I did a quick search for more information, suspecting that the Varicon was a similar tool to the Panaflasher, and found this blog by DP Rob Draper:
http://www.robdraperacs.com/2011/11/varicon-creativity-and-dynamic-range/
He writes:
And as I read this blog post, it all sunk in: duh! This is a fantastic tool! I dare say, an underused one. And the great thing is that it's arguably more useful for digital than for film - how about that?
Think about it: you're using something like a Sony A7 or a Panasonic GH5, and you're shooting compressed codecs. And you want to protect your highlights, so you might underexpose a little bit. The Varicon encourages you to do that, while lifting the light from the shadows (not really, but stay with me) to compensate for your underexposure. You then don't have to lift the shadows in post because they're already lifted. In fact in some cases you might want to pull your shadows back down. The benefit: cleaner shadows, no matter what you do with them.
Whereas with film, you have the ability to overexpose by one or two stops without too much of a penalty in the highlights. You don't really want to do that with a compressed codec.
So basically, the Varicon does two things: modify your tone curve, giving a quasi-log profile to the image; and it reduces noise while introducing no artefacts. It also seems to look better than low con filters (which I never liked but could see use for) while introducing zero halation.
I would only disagree with Draper's statement that the Varicon gives "approx 1-2 stops more detail in the shadow areas." I don't quite think that it works that way, as there is no free lunch here. However, the appearance of more shadow detail makes sense, as the noise is mostly gone.
A final note: the Monstro is such a good sensor that you probably would never need something like a Varicon. Those shadows are clean as the Queen's teaspoons. But it would be a very useful tool for hybrid cameras like the GH5 mentioned above, as well as for cameras with the MX sensor.
If you've used one, do let me know what you think of it.
For scenes taking place during earlier time periods in the script, Le Saux wanted to encourage a sense of pastel colors, subdue the contrast and reveal shadow details, appropriate to the film's retrospective mood. This saw him frequently flash the negative – a technique pioneered by such legendary cinematographers as Freddie Young OBE BSC and Vilmos Zsigmond HSC ASC. For this he deployed an ARRI Varicon at different intensities with a 1/2 CTB gel filter, sometimes with an 1/8 SFX or CS diffusion filter in addition. To further cultivate the effect of flashing via the Varicon, the footage was push-processed by one stop at the lab.
He writes:
I could never understand why more DP’s, especially those shooting for TV, did not use the Varicon. The advantages were obvious.
