V-Raptor DSMC3 Monitor losing power
jake southard
Beverly Hills, CA
www.jakesouthard.net
Anybody else having issues with the DSMC3 SmallHD monitor on the raptor losing power when when handling the camera? Specifically during rougher movements such as connecting an easyrig quick release to the top handle, or mounting the camera to a tripod head. Really, when any force is applied to the DSMC3 monitor mount. I'm sure the pins are briefly losing connection, but it's bolted down tightly.
And yes, i've tried disconnecting the DSMC3 monitor base and cleaning the pins and re-seating, as well as checking the monitor cable.
Just me?
I had an AC out too much tension on my monitor cable and the monitor started cutting out when handling it. I replaced the cable and it’s been perfect.
If you’ve replaced the cable it’s likely one of the connections. Have you tried slightly wiggling the cable independently on the monitor side, then the camera side to see if the issue only happens on the camera body/monitor connections?
It definitely sounds like you’ve tried everything in your control. It’s probably time to send it in. Make sure you document the issue well. Videos can be a massive help for them to diagnose the issue. Good luck
