Eli Jarra
- Dec 30, 2006
- Los Angeles
- www.thinkpictures.com
I was stoked to hear about this undocumented feature, and a couple days ago I got to try it for myself. Since we were doing 3D tests, I can't even tell you how much easier things were doing master/slave control on both bodies. Especially with the Origo.
I wanted to post my observations during our test. One of the things that wouldn't translate between the two cams was changing the Varispeed settings. That had to be done manually on both cams. Also, a couple of times, the slave camera would lose ALL button functionality on the body so if you needed to adjust a setting, there was no way to do it. As if the camera fully locked up.
Only a reboot would get you back, but you had to be careful...if you restarted the camera with the usb still connected, camera would always power up stuck on the white screen on the back display and never fully boot. Only disconnection of cable seemed to remedy this.
Just wanted to share...
Build 17's
both cams locked to 59.94 sync from Aja box
LCD's and EVF's connected
sdi preview connected to on-set monitoring
Build 17's
