Andy Ambarita
New member
- Mar 1, 2013
I've just been just bought a Red Epic, and Im having trouble with the monitor. Ive replaced the standard Zephyr SD monitor with a HD Panasonic BT-LH80W. But when i turn the monitor on and switch it to SDI Input, the monitor reads "unsupported format",also i've bypassed my rig and went direct from Epic to monitor and still the same outcome. I was wondering if any one had the same issue with this monitor or similar issues with other models, and if there were any settings i could change on the EPIC to fix this issue.
These are links to the monitor I'm talking about:
http://www.bhphotovideo.com/c/produ...BT_LH80W_BT_LH80W_7_9_Multi_Format_Color.html
http://www.picturehire.com/pdf/Panasonic BT-LH80W.PDF
Cheers
Cheers
