Unpredictable audio inputs on PRO I/O?
Thomas Koba
During days, where we use the Pro I/O for audio, I often loose the signal after a battery change (reboot). Running a phantom powered Sennheiser 416, I sometimes need to go into audio settings and switch from BALANCED to UNBALANCED, exit the menu window, go back into audio settings, and switch back from UNBALANCED to BALANCED to get the signal back. Sometimes this does not work, and I need a couple of reboots of the camera. These reboots have been made with and without the XLR and microphone plugged in.
At other times, everything is fine after a battery change (reboot).
Overall it seems to me, the input ports are kind of "not initializing" predictably everytime I restart.
Has anyone else experienced the same?
Tried it on older Firmware (can't remember which version) and on the newest non-beta version.
