[FS: GEAR] TV LOGIC - MONITOR 5.6 ****** VFM-056WP
tim ara
REDuser Sponsor
LOS ANGELES, CALIFORNIA - USA
www.cinoflex.com
For Sale - USED TV LOGIC 5.6 HD Monitor VFM-056WP
Monitor only - $525.00
P-Tap cable - $50.00
All have been professionally maintained and calibrated by TV LOGIC in Burbank
They all are calibrated and cleaned before sale
These are the WP models which have the "advanced" feature of HDMI to SDI conversion - use to be $300 extra just for that upgrade
All include the original shield and AC power supply / right angle BNC / top and Bottom mounting hardware - everything included like original brand new unit - minus the box
Come test it, bring a camera if you'd like
contact direct for fast easy communication: TIM@CINOFLEX.COM or SALES@CINOFLEX.COM
TV LOGIC - VFM-056WP : 5.6” Light Weight Compact Viewfinder
The VFM-056WP is available in two configurations and is ideal for HD-SLR production. A 6"x 4"x 1" lightweight magnesium-alloy case houses a 5.6” 1280x800 LED backlit LCD display with a full complement of preferred features, including DSLR Scale, Focus Assist, Various Scan Models, Markers, Audio Level Metering with speaker, Time code Display, HDMI loop out via HD-SDI(720p), WaveformVector Scope, Y Level Check and Range Error Check.
Display Spec.
Size 5.6"
Resolution 1280 X 800 (16 : 10)
Pixe Pitch 0.094mm
Color Depth 16.7M
Viewing Angle 170°(H) / 170°(V)
Luminance 300cd/m2
Contrast Ratio 500:1
Display Area 121(H) × 76(V) mm
Input
1 X RCA Analog Input (Composite)
3 X RCA Analog Input (Component)
1 X BNC 3G-SDI A Channel Input
1 X HDMI HDMI Input
Output
1 X BNC 3G-SDI Output
Audio
Audio Out Analog Stereo (Phone Jack), Internal Speaker(Mono)
FPGA Functions
, 3G-SDI Level A/B, Audio Level Meter Display, Blue Only, Focus Assist, H/V Delay, Luma(Y') Zone Check, Marker, Max Brightness On/Off, Mono, Range Error, Temperature Adaptive Color, Time Code Display, User Aspect, Various Scan Modes, Waveform/Vector, Zoom
Closed Caption
Calibration
Other Functions
USB Firmware update by USB cable
Ethernet
Conversion HDMI-to-SDI, SDI-to-SDI,
