Trouble with HD SDI and Panny Monitors?
Troy Bakewell
Has anyone else experienced an issue with the HD SDI out of the Scarlet and Panasonic BT LH monitors? I'm having a hard time. It's almost as if the signal out of the Scarlet is weak compared to the AF100 I had before it. The signal cuts in and out all the time. I've tried different cables. I'm having the same problem with other Scarlets as well.
Is there a signal amplifier I can buy?
I've tried everything in the menus.
Anyone have a suggestion?
Thanks in advance.
Hummm
Nobody else is experiencing this?
I've had issues with our Scarlet and a Panasonic LH80W. Not with the signal cutting out but with the picture splitting horizontally (starts with 1/10th of top of frame moved to the bottom of the screen). Seems to be all is well until you magnify, then it starts. With each magnify the split gets even worse.
Of course. Same thing happens on our Cube 155. This monitor has zero issues monitoring from either of our R1s. Running 3.0.7.
Yes, it is odd....I have 3 of these monitors and the oldest works great: BT-LH1700. The 1710 & 1760 cannot give me a waveform with the Epic or Scarlet output...but the older monitor can.
The issue Im having is the picture cutting in and out. Its very strange. I have two monitors and they both do it. Its not my camera because it happens with other scarlets too. Ive swapped cables. Im about to buy a sdi amplifier.
Had our crew report this problem from the field, cutting in and out SDI, we got the camera back home and hooked it up to a 17 Panasonic and ran 150ft of cable not problems. could not duplicate the problem.
