- Thread starter
- #21
Peter Majtan
- Feb 29, 2008
- Tokyo, Japan
- www.petermajtan.com
In which case improving the signal to noise ratio is the way toward improving dynamic range.
You are right. But it does matter HOW You improve the SNR. The two methods are NOT the same, but they are complementary. In which case - according to Your logic - one would benefit by using both and there will be (I dare to say) great difference between gaining DR by "just" downscaling the image and gaining DR with Sensor that has greater DR in a first place and then downscaling the image...
Please, both of You, I am not saying gaining DR by image reduction is wrong. It is just NOT THE SAME THING as gaining DR with better sensor. What if You needed the full unscaled image? The better sensor (with higher DR / less noise) will make all the difference...
