David E. Rogers
- Feb 26, 2013
set of TCS TRX+, WiFi Master and miniTX. All in working order along with some cables.
miniTX with external 9v power supply (firmware is 5.03) no serial number in display. This unit accepts TC in via BNC, only transmits TC, no WiFi. $100
WiFi Master, (Firmware is 5.3, sn 010543). Accepts TC in and out via BNC and Lemo, plus Sync (Word or Genlock) via BNC. External power from 4 pin Hirose or two AA batteries stored internally Transmits WiFi TC around the set in addition to transmitting TC to cameras. $350
5- miniTRX+ are current production. (Firmware is 4.27, sn are 51534017,51530005,51411001,51405005,51437003) Accepts TC in and out via BNC, plus Sync (Word or Genlock) via BNC. Bottom BNC will also output TC at (low or mic levels). External power from 4 pin Hirose, plus internal battery good for about 12 hours. The factory units come with 550mah batteries, these five units had 600mah batteries installed last fall, so perhaps a bit long run time. If used with a :wave or
ulse to connect to the BLINK Hub production dashboard. This unlocks the advanced capability to view, monitor and control multiple :minitrx+ units centrally from any smartphone (iOS or Android), tablet or computer.
Please note the Wifi Master does not offer Blink Hub.
Each miniTRX+ includes a BNC to BNC cable (lengths vary), D tap to Hirose power cable and right angle BNC to 5 pin Lemo for TC out of the TRX+ If you were to buy these cables new figure close to $200. New miniTRX+ are $475. Buy one or all with cables for $140each.
Shipping and Paypal not included.
Full details are available on the https://www.timecodesystems.com/ website.
Questions, please ask.
