[FS: GEAR] The Manfrotto 504HD Head w/546B Tripod System
Used this setup a couple times. Works great. Asking for $799 + Shipping OBO
-Matt
The Manfrotto 504HD Head w/546B Tripod System combines the innovative and stylish 504HD Fluid Video Head with the 546B Pro Video Tripod, creating an ideal combo of affordability, stability, and smooth, precise control. This compact, versatile system was designed with independent video and DSLR shooters in mind, and provides the level of ergonomics and support required by todays small crews and one-man bands.
504HD Fluid Video Head: The 504HDs patented Bridging Technology allows for a wider top plate and longer sliding plate that add stability and balance to a set of state-of-the-art professional features. A newly designed counterbalance system includes four presets--from 0 to 16.5 lbs--enabling proper balance for camera loads up to 19.8 lbs, while 3/8" threads in the top plate allow attachment of monitors, arms, and other accessories directly to the head.
546B Tripod: This aluminum two-stage tripod combines stability and strength with affordability. Reaching a maximum height of 60.6" (154cm), the 546B is capable of supporting up to 44 lbs (20kg). Its spiked feet come with rubber overshoes, allowing setups on both smooth floors and uneven surfaces, while a newly designed mid-level telescopic spreader keeps the legs exactly where you need them
Items Included: 504HD Fluid Video Head, 504HLV Pan Handle, 546B Pro Video Tripod, Carrying Case ,
