Jed Williams
- Sep 8, 2016
$2250 OBO
Local pickup in Burbank, CA or will ship. prettyniftycommercials@gmail.com
Selling this used but excellent condition Teradek Bolt Pro 300. Never had any issues, works perfect. Always stored in a Pelican case, very few hours used. Any questions let me know.
Transmit uncompressed 1080p video wirelessly over 300 feet with the Teradek Bolt Pro 300 3G-SDI Wireless Transmitter-Receiver Set. Included in this set are a Teradek Bolt 300 transmitter and receiver both equipped with 3G-SDI ports. The units in this kit are compact and feature internal antennas so they can fit on your camera rig and in your video village, DIT cart, or director's monitor rig.
When transmitting uncompressed video, latencies of less than one millisecond can be achieved if no other video processing is necessary. Unnoticeable latency is important for directors and focus pullers to see the action at the same time the camera does.
A boon for DITs, the USB GRAB engine streams the uncompressed video straight out of the receiver and into a PC for immediate recording. With this video available, rough edits can be made even before the footage is offloaded from the camera.
Bolt 300 3G-SDI Wireless Video Transmitter
The Teradek Bolt 300 3G-SDI Wireless Video Transmitter accepts SDI signals and can transmit them to a Bolt 300 Receiver up to 300 feet away in optimal line-of-sight situations. The Bolt system supports uncompressed video resolutions up to 1080p at 60 fps with 4:2:2 chroma subsampling. Because the Bolt system uses the 5 GHz wavelength, it does not require FCC licensing. Included with this transmitter is a shoe adapter to mount the unit to a camera's standard accessory shoe and a D-tap to LEMO power cable so you can power the unit with an onboard battery with a D-tap output.
Bolt 300 3G-SDI Wireless Video Receiver
The Teradek Bolt 300 3G-SDI Wireless Video Receiver accepts video transmissions from a Bolt 300 transmitter up to 300 feet away in optimal line-of-sight situations. The Bolt system supports uncompressed video resolutions up to 1080p at 60 fps with 4:2:2 chroma subsampling. Because the Bolt system uses the 5 GHz wavelength, it does not require FCC licensing. Aside from being able to output video via 3G-SDI, the USB 3.0 port can stream the uncompressed video directly to a PC for recording with the GRAB Engine.
Included in box:
D-Tap to 2-Pin LEMO Cable
SDI Cable
Manual
Included in box:
SDI Cable
Manual
