Mike Milia
- Aug 22, 2013
Specs
Model Number
B&H # TE100770
Manufacturer # 10-0770
Transmitter
Input SD/HD/3G-SDI
Output Looping 3G-SDI
Resolution Up to 1080p60
Frequency 5.1 to 5.8 GHz
Wireless Range 2000' (609.6 m)
Power 7 W
Cable Lemo 6 to 28 VDC input (Pin 1 GND, Pin 2 +DC, 0B 302 series Lemo)
Encryption AES128
Audio 2-channel
Chassis Milled aluminum
Mounting Multiple mounting options with 1/4"-20 holes
Mount Accessory shoe mount
Temperature 32 to 122°F (0 to 50°C)
Dimensions 4.3 x 2.6 x 1.0" (10.9 x 6.6 x 2.54 cm)
Weight 8.8 oz (249 g)
Receiver
Output 2 x SD/HD/3G-SDI
Power 6 W
Cable Lemo 6 to 28VDC
Mounting Multiple 1/4"-20 threaded mounting hole
Dimensions 6.0 x 4.6 x 1.0" (15.2 x 11.7 x 2.54 cm)
Weight 1.05 lb (476 g)
Whats in the box
(1) TX
(1) TX P-Tap Power Cable
(1) RX
(1) RX AC Power Cable
(2) 2' BNCs
(1) 1/4"-20 TX Tie down
(1) 1/4"-20 Baby pin
(1) Teradek Pelican Case
Model Number
B&H # TE100770
Transmitter
Input SD/HD/3G-SDI
Power 7 W
Encryption AES128
Audio 2-channel
Receiver
Power 6 W
Whats in the box
(1) TX
(1) RX
(2) 2' BNCs
