Jeffrey Wright
Hi! I'm a long time Red shooter that is just getting into figuring out timecode so I apologize if this is super obvious. I've researched quite a bit and still have questions.
I've used a combination of Tentacle Sync E's and Zaxcom ZFR 300's with DSMC1/DSMC2's on shoots with good luck. We would use the Sync E's to jam each camera and then the Sync E's to the Zax's from that.
I'm planning on buying one or two of the Track E for my own kit and would like to know if it's necessary to use a Sync E in the process and haven't been able to find much info. I understand that the Track E can receive timecode but cannot output timecode.
One camera shoots:
Is it possible to send the TOD/TC from the camera to the Track E with this cable: https://www.bhphotovideo.com/c/product/1327590-REG/tentacle_sync_c01_cable_tentacle_to.html (if so, will this be frame accurate for an entire day?)
Two+ camera shoots:
Can I jam sync two or more (RED) cameras without the need to use a Sync E? If so can I just jam the two cameras and then jam the Track E from one of the already jammed cameras? What cable do I need? Could I use a BNC/SDI cable? 4 pin Lemo to 4 pin Lemo?
Many thanks!!
Jeff
One camera shoots:
Two+ camera shoots:
Many thanks!!
Jeff
