Trevor D K
- Feb 21, 2016
Any thoughts or experiences please on the using the Syrp Magic Carpet slider with the Epic X ?
Syrp indicates the slider has a load capacity up to 15.4 lbs, my stripped down Red with an L series Canon works out at approximately 8 lbs, so theoretical this should be a breeze...
I’m sure this would be ok with horizontal tracking movement and hopefully “buttery smooth'' as marketed, but how does it perform with vertical movement using their counter weight system ? I would be buying the kit blind hence the concern.
I have no doubt that the slider is great when combined with the Syrp Genie and a DSLR for time lapse motion control work, which I would also be using it for, but also plan to use it for real time movement with the heavier Red with or without the Genie ...
